Topic:   Auto filename when saving?
By: LukePosted on: Oct 19 2017 at 03:10:39 PM
Is it possible to have the software automatically naming files whenever saving programs to pc, by having the desired filename in comment, on the 1st line.
Some other software have this kind of behavior whenever a program is saved to the computer.
By: GuestPosted on: Oct 20 2017 at 05:27:57 PM
When "Remo" mode is active then the software will automatically name and save the file.
By: GuestPosted on: Jan 9 2018 at 11:38:09 AM
will the filename 01 then renamed ? What is the "Remo" mode?
By: GuestPosted on: Jan 9 2018 at 11:41:47 AM
In normal mode when you send a file from the CNC to the computer the file stays on the computer display until you click the save button and save the file, naming it if necessary.
In Remo mode the program saves a file received from the CNC using the name that was detected within the file.
You can download the user guide on the downloads page.
Topic:- Auto filename when saving?
