Topic:   Burny 3
By: GuestPosted on: Mar 3 2017 at 10:37:47 PM
I have an older burny 3 on cnc plasma system. I have been using FastLINK to connect my pc to the controller. Computer recently died. FastLink and my Black Box modems was a serial port connection. I bought a new computer with USB, bought the serial to USB from Black Box. I downloaded another software and have yet been able to successfully load a program from the controller. The old process was: set your gcode file in a folder that FastLink set up. When you called up that program number from the controller it downloaded into the controller and then I was able to run the program. I am now looking for a connecting software to do the same.
Help please. Thank you for any help.
By: GuestPosted on: Mar 5 2017 at 01:57:59 PM
In your post you said that you "Called up that program number".
What was the process of calling up a program number? Do you mean that you put the CNC into a state where it's waiting for data and you then 'sent' the data by selecting it and 'sending' from the PC?
Or some method of sending a request from the CNC ? If so could you describe that process?
Topic:- Burny 3
