Topic:   HAAS communication settings
By: Michael Posted on: May 15 2010 at 07:58:02 PM
we have a haas vf-2 & haas vf-4. I did not see haas listed in your NC table, could you please give me the recommended settings for both the machine & easyDnc? Thanks.
By: Support Posted on: May 16 2010 at 01:44:29 PM
Settings in the CNC
Serial Port = Main
11 Baud Rate = 9600
12 Parity = Even
13 Stop Bits = 1
37 Databits = 7
14 Sync = XonXoff
24 Leader = None
25 EOB = CR/LF
41 Spaces = On
50 Aux Sync = XonXoff
54 Aux Baud = 9600
69 Leading Spaces= Off
70 Open/Close = On
Dnc Software settings are:-
Mode = None
Baud = 9600, Databits = 7, StopBits = 1, Parity = Even
Flow Control XonXoff
Leave everything else at the defaults.
By: GuestPosted on: May 26 2014 at 09:06:23 AM
RemoDNC 5 also does Haas xmodem
By: GuestPosted on: Oct 25 2017 at 07:02:21 PM
cannot get HAAS to accept drip fed code. 411 empty program error only comes up with these specified settings.
do you have a email i can contact .
By: GuestPosted on: Oct 26 2017 at 06:28:51 PM
I assume you try to send the program to the cnc but nothing happens and the cnc just sits waiting so you press cancel at the cnc and that's when the 411 alarm appears. Is that what's happening?
Are you sure all of the parameters, baud rate etc are correct?
Ignoring drip feed for a moment. Are you able to send programs into the cnc memory?
Are you able to send a program From the cnc to the computer? Put the DNC into receive mode and send from the cnc. Does anything, even garbage, appear on the computer display?
By: GuestPosted on: Oct 29 2017 at 10:07:01 PM
Nothing is transfered either from or too the cnc. I've tried multiple matching parameters with no luck.
i am only on the demo version, Could this be the issue?
i can transfer saved programs using serial from my mac to the haas without issue other than limiting my file size to the haas memory.
thanks
By: GuestPosted on: Nov 3 2017 at 12:59:17 AM
Any suggestions?
By: GuestPosted on: Nov 19 2017 at 01:59:09 PM
You can transfer from your 'MAC' to the haas? What software are you using on the MAC ?
By: GuestPosted on: Dec 30 2017 at 11:23:16 PM
By using "brackets" program to edit Gcode then i use "Serial" program on my mac to transfer a file from the mac to the haas control but i am limited by space on the haas control.
i tried drip feeding with the demo version of your program and i haven't had luck getting anything to transfer or drip feed.
thanks
Topic:- HAAS communication settings
