Topic:   Tnc 370 can receive files but it can't send them ?
By: GuestPosted on: Aug 15 2015 at 02:05:00 PM
hello we have a tnc 370 we have managed to send files from the machine to your softare but not the other way round the animation starts spinning but stays at 0% for 10 mins plus.... is there a simple cure for this?
regards chris
By: GuestPosted on: Aug 15 2015 at 07:30:43 PM
If the DNC software is configured to use 'Blockwise' then also ensure that blockwise is enabled in the CNC (Parameter 5030=1 I think)
If not using blockwise (5030-0) then make sure the DNC software does not have the 'wait' option enabled. Prepare the CNC for receiving data and then go to the DNC computer and hit the Send button
By: GuestPosted on: Aug 15 2015 at 07:50:43 PM
okey thank you we will have a look on Monday how do you get into parameters ? also if i go on the page with baud rate (on the mill) i and lower it its still at 9600.
By: GuestPosted on: Aug 15 2015 at 08:19:40 PM
Baud rate isnt the cause of the problem you described in your first post.
The problem is that the DNC is sat waiting for a Start signal from the CNC and the Start signal doesn't come.
It kind of sounds as if the DNC has blockwise enabled but the CNC doesn't.
First thing to try is to leave the cnc settings as they are.
In the DNC unset the blockwise and set to xonxoff instead.
Get the dnc software ready to send but don't click send yet.
Put the cnc into data receive/read or whatever its called (so its waiting for data)
Go back to the computer and click Send.
By: GuestPosted on: Aug 15 2015 at 09:51:04 PM
excellent help i will go down and try tomorrow also is this drip feeding or uploading to its memory ?
By: MarkGuestPosted on: Aug 16 2015 at 06:48:52 PM
What the previous 'guest' suggested would/should work for both drip feeding and loading into cnc memory. Obviously you'll be selecting different options in the CNC but the DNC doesn't care either way.
If you are drip feeding then i'd suggest using blockwise.
By: chris Posted on: Aug 17 2015 at 10:29:23 AM
now all we are getting on the cnc is (1 .H)
setup as follows on the dnc
end of block=ignore
block delay=0
data bits and parity=7bits even
xonxoff
mode heidenhain
By: chris Posted on: Aug 18 2015 at 03:27:51 PM
any advice ?
By: GuestPosted on: Aug 18 2015 at 08:29:58 PM
Only way we could get ours working was with blockwise enabled.
By: GuestPosted on: Aug 18 2015 at 11:54:44 PM
oh okey so did you send files in .H or .TXT what file names do you send ? and to confirm vmc 370?
Topic:- Tnc 370 can receive files but it can't send them ?
