Topic:   Traub System TX 8F control
By: BaoPosted on: Apr 3 2012 at 05:47:25 PM
I was wondering if I could get help connection parameters along with pin connections.
By: GuestPosted on: Apr 3 2012 at 05:56:33 PM
See here
Traub TX8
By: SEANPosted on: Sep 15 2013 at 02:25:06 PM
IS THE TX 8F A MITSUBISHI CONTROL OR OTHER?
By: Guest Posted on: Sep 15 2013 at 07:46:03 PM
The control is probably mitsubishi but as far as dnc settings are concerned it'll be quite simply a case of making sure the baud rate setting in easyDnc is the same as the traub and 7bits even parity. Make sure the traub is set to transmit/output ISO (Not EIA)
And leave the rest of easyDnc settings at their defaults (auto).
As for the DNC cable. If you look at
Traub DNC Setup
you'll see a slight difference between the suggested mitsubishi and the traub cables. They're not actually different, though, just unused pins wired differently. So either of them will work.
By: GuestPosted on: Apr 26 2017 at 08:28:22 PM
Years ago we had four Traub TX8 lathes. Sending a program out to the computer was very simple. But getting a program in to the CNC was strange. The CNC console has both 'IN' and 'OUT' buttons but I discovered that I didn't actually need the IN button. I'd just punch out the remo 'runner' to request whatever cnc program I wanted to run and then just stand back and even though the traub still has its 'out' mode it still accepts, reads in, the program being sent from the DNC computer.
By: AminePosted on: Sep 9 2017 at 09:53:53 AM
Problème de pompe qui ne fonctionne pas.
By: AminePosted on: Sep 9 2017 at 02:53:52 PM
Défaut de démarrage, pompe ne fonctionne pas.
By: SupportPosted on: Sep 11 2017 at 06:43:54 PM
Sorry. I don't understand. "Pump does not work?" What pump?
By: GuestPosted on: Jan 5 2018 at 08:02:29 PM
Where can I find management instructions?
By: GuestPosted on: Jan 8 2018 at 03:14:50 PM
Management instructions? Do you mean information about using the software?
go to
www.easydnc.com
By: Lio SantanaPosted on: Mar 1 2018 at 08:55:21 AM
Someone solved the problem with connection of TX 8F? I have the same issue, I can withdraw programs from CNC to PC but not otherwise.
By: GuestPosted on: Mar 1 2018 at 02:43:24 PM
Send any file from the cnc. Then while the traub is still in out mode go to the pc and send the file to the traub.
Sounds strange having the traub in OUT mode when you send a file from the PC. But on our traub that was the the only way i could get a file into the traub.
By: Lio SantanaPosted on: Mar 6 2018 at 07:55:49 AM
Did not work, which DNC program you have?
By: Lio SantanaPosted on: Mar 7 2018 at 07:37:28 AM
I already found the solution, I deleted the % from the begin of the program.
By: GuestPosted on: Oct 23 2021 at 11:09:29 AM
c'est quoi le role mitsubishi lx83a board traub tx8 ?
By: GuestPosted on: Sep 3 2023 at 12:44:25 PM
Hello everyone.I need list of parameters of TX 8F control.can anyone help me?
Topic:- Traub System TX 8F control
