Topic: 21T Control Sends Gibberish to PC
By: Rick WhittakerPosted on: Jul 31 2009 at 10:38:29 PM
Cobra 21T control reads programs from EasyDNC fine, but uploading a program using punch command back to the PC just sends gibberish, all kinds of strange characters. No alarms. Replaced the cable, but same thing. It used to work. Any ideas?
Rick
By: SupportPosted on: Aug 1 2009 at 05:39:33 PM
When you've sent the gibberish would you save it to a file and then email it to me please
support at easydnc dot com
By: SupportPosted on: Aug 4 2009 at 09:04:22 PM
Thanks for sending the file
Your CNC appears to be outputting in EIA format
In the CNC you'll see a parameter with the option EIA selected. Do you see the options ISO (or ASCII)
Switch that option to ISO (or ASCII)
By: RickPosted on: Aug 4 2009 at 09:38:30 PM
Thank you, I set the 21T control parameter to ISO and everything worked perfectly. Not sure how a parameter like that got changed, but out in the shop, anything is possible.
