I have remodnc running with our milling machine.
but I can't make a tool change.
at set N80M66
I get the error message 078.
Everything else works.
M66 is the command for the machine to change the tool
Posted on: Sep 29 2022 at 01:08:01 PM
Error 78 is:
A program number or a sequence number which was specified by address P in the block which includes an M98, M99, M65 or G66 was not found.The sequence number specified by a GOTO statement was not found. Otherwise, a called program is being edited in background processing.Correct the program, or discontinue the background editing.
Posted on: Oct 3 2022 at 06:32:13 AM
If you're drip feeding and you make M98 calls out to a sub routine/sub program then that sub program needs to be in CNC memory.
Posted on: Sep 18 2023 at 12:59:45 PM
078 number not found
Posted on: Sep 19 2023 at 10:25:18 AM
Sub routine not found. Any called subs need to be in memory.
By: Patel maheshkumar jayantibhai
Posted on: Nov 20 2025 at 10:55:05 AM
Vmc machine tool chenj 078 p/s alarm
