Trying to communicate with this older control and I am having trouble setting it up. Running at 2400 baud 7 data bits, one stop bit with rts and cts control codes. Getting a record overflow alarm, are there any special characters I should be using at the beginning and end of the lines?
Posted on: Mar 25 2014 at 08:39:30 PM
RTS/CTS will only work if the cable has the relevant pins connected. If you have a simple 3 wire cable then it isn't going to work with rts/cts. Try using xon/xoff instead.
