| By: Guest | Posted on: Dec 27 2011 at 10:41:08 PM | | If you're asking how to drip feed a program from easyDnc then it's simply a case of preparing the fanuc ready to work, tool, workpiece etc ready to go, put it into Tape Mode and press cycle start on the fanuc. At that point the CNC doesn't do anything. Go to easydnc, select the program you want to run and press the Send button. As data starts to flow the CNC starts cutting/machining. | |
