Topic: Brother TC-229, 1996
By: John1987Posted on: May 29 2017 at 02:51:20 PM
Hello. Will it work with Brother TC-229, 1996 year of manufacturing? I do not know what type of the controller on this machine. Seems, that Brother produce their own type of controllers...
By: GuestPosted on: Jun 1 2017 at 11:17:37 AM
Should work with most controllers.
In RemoDNC setup just select the MODE=AUTO option and make sure the baud rate is set the same. Leave all the others at their defaults.
Then, put the computer/DNC into Receive mode and go to the CNC and send/punch out a program.
What do you get on the computer display? Anything at all? Garbage?
If everything looks good then you're pretty much good to go. But if it's garbage then take a look at the garbage. Is it 100% garbage? or do you see a lot of good characters maybe around 20 to 50% random characters are garbage? In that case the baud rate is correct but the DataBits/Parity setting in DNC setup is wrong.
Once you get 100% good characters yoou can try sending a file to the CNC. How does that go?
By: GuestPosted on: Nov 25 2020 at 08:43:46 AM
do you have connect dnc with brother TC-229? Can you help me setup it?
Thank you very much!
my email: phuvinh77@gmail.com
