| By: Support | Posted on: May 3 2011 at 10:44:08 PM | In easyDnc setup window is an option "BlockDelay". Make sure that is set to a low number or even zero, fast or none ( no delay).
If it is still too slow can you try the update from www.easydnc.com that will be version 4.7h. In that version set the block delay to zero and disable smart pace.
4.7a does not have a smart pace option. That's only in 4.7h.
I'd suggest trying 4.7a without any block delay and then, if that doesn't help, upgrade to 4.7h and try that. | |
