Home
Prices
Topic: Can't send files to Sinumerik 840D
By: Zazar
Posted on: May 12 2009 at 03:52:29 PM
It seems that i can`t send files to the CNC but i can recive data from the CNC machine. Both machine and easyDnc are just waiting and nothing happens when i try to send a file to the machine.
CNC controler is Sinumerik 840D
Posted on: May 14 2009 at 12:44:01 PM
Sounds like flow control.
This web page shows two cable diagrams - 1 and 2.
Sinumerik CNC DNC Settings and Cable
I know that shows the 810 but the cable is the same.
If flow control in easyDnc is set to RTS/CTS then your cable must connect the pins as shown on [Cable 2] of that webpage.
If your cable is wired as per [Cable 1] then you can only use flow control `xOn/xOff` or `None`.
Do not use one of the `Wait` options in easyDnc`s flow control setup.
