Topic: Connecting more than one machine to the same computer.
By: MikePosted on: Mar 12 2009 at 06:06:29 PM
Most computer have only one or two serial ports. How would you connect four machines to one computer? I`m assuming you would need some sort of a hub. Any recommendations for what works well with your software?
By: GuestPosted on: Mar 16 2009 at 06:16:41 PM
You can purchase a 4 port MultiPort card/adapter quite low cost. This would usually be a PCI card that you slot inside the computer and on the outside is a distribution box or cable-set with with the 4 extra ports.
If the machines are some distance away you can get an ethernet port-box. That`s a box with 1 ethernet port and 4 com ports. You onnect it somewhere to your company ethernet network. Once the drivers are installed these ports appear to easyDnc just as if they were local Com ports
By: GuestPosted on: Mar 18 2009 at 02:51:10 PM
Thanks, sounds simple.
