Topic: Conversational Machine
By: JustinPosted on: Feb 1 2011 at 05:19:06 PM
I have a Milltronics Partner II conversational machine with a Centurion IV Controller. I have not found any combination of settings that will read my programs from the machine. When I try to do a Port Scan I get a Run-time error '1009': Error Setting Port's Characteristics ExtErr
I have tried several other DNC softwares with no luck. I currently am using a MSDOS File Transfer, but it will only run on a 32 bit Windows, and we now have a new system that only runs 64 bit. Someone please advise!!
By: Support,Posted on: Feb 1 2011 at 08:16:25 PM
Tell me about your Dos program. What's it called, where does it com from?
By: Justin,Posted on: Feb 3 2011 at 01:28:38 PM
It is the File Transfer for SmartCam. I used all the settings that are called out in it for that software that currently work with it. For some reason I can't get it to recieve using this software or EdgeCam's file transfer. The settings on the old Dos system are 7, even, and 2 with a 110 baud rate. I've tried changing around several settings with the EasyDNC, but to no avail...
By: t,Posted on: Feb 3 2011 at 08:17:01 PM
When you send data from the CNC to easyDnc does anything appear on the display ?
