Topic: define storage path in program
By: PeterPosted on: Mar 10 2019 at 10:59:23 AM
Hello...
On request you can define the path of the program
:9999
(SEND CNC/00005/6676)
M30
Is it possible to define the store path in the program when sendig the programm form the machine?
example:
:6676(SCREW M8-100)
(-CNC/00005/6676.TXT)
(CNC PROGRAM)
M30
- is the prefix
Greetings from Germany
Peter
By: SupportPosted on: Mar 11 2019 at 03:47:32 AM
Sorry. No. This isn't possible.
The storage path is configured in RemoDNC setup. Each CNC can have a different storage folder.
Most people set this up to a folder with a name such as 'UnChecked'. Everything coming from that CNC goes into the /Unchecked folder. The idea is that files from the machine do not overwrite good files on the computer. You could then periodically check the files in the UnChecked folder before moving them to the good folders.
I think this is safer than allowing machine operators to send files for storage to the computer overwriting any files they wish.
cyfarchion o cymru
Jess
