Topic: Digi serial controllers
By: GuestPosted on: Mar 29 2013 at 02:46:34 PM
Has anyone ever successfully used easydnc with a Digi, specifically a TS2? If mind sharing your pinouts and settings? Thanks!
By: Guest Posted on: Mar 29 2013 at 05:04:52 PM
Digi are a well known brand - shouldn't be any problem with them at all.
Pin outs for digi products - the ones with standard 9pin D male connectors - should be the same as a standard PC Com Port so no special wiring required.
For cnc specific pinouts and other settings see the dncsetup.com website.
www.dncsetup.com
