Topic: DNC or dripfeed Epson SRC-320 robot controller with ES651 and ES653 SCARAs
By: #51Posted on: Mar 7 2011 at 08:17:20 AM
Hi
I would like to use dncxp to DNC or dripfeed 2 Epson Robots with controllers SRC-320.
Could you please inform med if the program is suitable for such joba and if there are any settings/pre programmed mode that is suitable for the job.
I am bulding a robotic milling machine that will handle 3D-milling.
By: Guest,Posted on: Mar 7 2011 at 07:59:22 PM
There's no preset options for those controllers. If they accept standard ASCII data such as CNC g code without any special ack/nack protocol then easydnc should be able to do it.
By: GuestPosted on: Jun 30 2011 at 02:40:46 PM
can anyone help me get a pc and SPEL for windows to communicate to a SRC 320 controller.I have made a cable up to page 25 of the manual and set to 9600,8,even,2 configuration
By: GuestPosted on: Jun 30 2011 at 07:58:48 PM
Are you sure 8,Even is correct.
Highly unlikely that the computer would be set to that.
8,None
Or
7,Even
