| By: netpipe | Posted on: Dec 28 2008 at 02:38:05 PM | I have a Bridgeport Boss 6 and do have it drip feeding. Not a simple task because it took me 1 year to investigate and get it working.
REGARDLESS of the type of software used.
The boss controllers are for the most part very dump. No handshaking therefore not able to tell the pc to wait or when to give it more data. Additionally, most of the Boss controllers only have 8K. That`s only 8,000 characters. Maybe 400 lines of code.
Currently, I do mostly 3D solids and the code generated has ranged from 9,000 lines to over 325,0000 lines of code. Never fails.
You MUST utilize a BTR (Behind Tape Reader) board. Some come with 8-32MB of storage. However, you don`t need to have the larger model. PC connects to one side of the BTR, the other connects to the Boss controller using the TAPE interface.
You need to inject some characters in your GCODE to tell the controller to run up to a certain point and when reached, it will dump existing memory and load the next block of code (size is adjustable).
Once it was working, it became a pain to manually ingest the commands into the code so I wrote a simple program to automatically do it for me. Takes about 3 seconds for 10,000 lines of code
I have given the program and detailed information (NO CHARGE) to anyone that needs it. | |
