Topic: Drip feeding system 20 Dynapath control
By: GuestPosted on: Nov 6 2009 at 11:55:54 PM
I have a problem drip feeding to a Dynapath system 20 control. When I hit cycle start on the control and it triggers the program to start from easy dnc, the code continues to feed when it should stop and start to prevent the control from overflowing the buffered amount. My settings are 1200 Baud rate with 7 data bits and 1 stop bit, parity even with x on / x off waiting. also cr lf at the end off each line. Also I am running the standard three wire configuration for rs 232 2-3 and 3-2 and 5-7. The sequence I go through is que up the program in easy DNC then hit cycle start on the machine, it starts the machine up and runs code but the easy dnc doesn't stop sending data when it should.
By: SupportPosted on: Nov 9 2009 at 10:39:40 AM
Does the DNC run right up to 100% even though it should have stopped.
What I mean is does the DNC eventually stop (not stopping quick enough) or does it not stop at all and just run right up to 100%
might be easier if you email us at
support at easydnc dot com
