Hello,
I am drip feeding to a deckel FP2A with dialog 11 milling machine. The program is send correct from easy dnc but when displayed in the machine sometimes a dot is transformed to a L or data is missing and even for example the linenumbers from N300 to N400 is placed after N600.
Does anybody has an idea what the problem could be? I already set my baudrate low en block delay on 200.
regards,
Fred Schenkel
By: MikePost,
Posted on: Dec 20 2009 at 04:32:59 PM
That example of line numbers appearing in the wrong order looks like a buffer overrun.
Are you using flow control xOnxOff or RTS/CTS ?
You'll only be able to use RTS/CTS if your cable has the correct wires connected.
