Topic:   Drip Feeding via USB-Serial Adapter
By: HLTPosted on: Apr 19 2023 at 08:27:28 PM
New PCs (or Laptops) no longer come with serial ports. Can successful drip deeding be carried out using via USB-Serial Adapter with the recommended cable configuration for FANUC CNC?
By: GuestPosted on: Apr 25 2023 at 08:52:09 AM
Yes. But baud rate not too high. Flow control xOn/xOff.
Go into windows device manager. Ports Com&LPT. Select the Com port. Go to "Advanced'. Slide FIFOs down to zero and disable. Some USB adapters have their own display in that FIFO window for managing fifo buffers while others just ignore whatever you set but go in there and disable fifo anyway.
Look in the easydnc setup window and see the 'Block Delay'. Increase that to a bigger number.
Topic:- Drip Feeding via USB-Serial Adapter
