9 Pins to 25 Pins
The control will not read pass line 5 even if dnc sent the entire Program
By: Gil
Posted on: Jan 19 2018 at 12:10:39 PM
The cable is wrong or the DM 3000 Control configuration wrong
Posted on: Jan 20 2018 at 04:38:54 AM
If the CNC receives only 5 lines does it then stop receiving with an alarm? What alarm/code/number?
Have you just got this machine or have you had it working long? Is the CNC expecting the Dyna proprietary code or is it working with standard G/M code? So does the machine 'like' what you're sending or is it simply stopping because it doesn't like the file format you're sending?
