Topic: Error when trying to send files larger than 66,000 KB
By: Carlos Coderch | Posted on: Oct 25 2024 at 02:50:32 AM | When I try to send a file larger than 66,000 KB the message “An unhandled exception occurred†type Siytem.OutOfmemory†appears on screen and recommends closing RemoDNC.
I am using a PC running Windows 7 Ultimate Servi pack 1, with an Intel Core (TM) 2 Duo CPU E6550 @2.33 GHz with 5 GB RAM (2.99 GB usable) - 32 bit OS type.
The Remo DNC is the demo version
Is it a problem with RemoDNC or with my PC? What is the solution? Thanks for your attention. | |
By: Support | Posted on: Oct 25 2024 at 03:42:32 AM | 66,000KB (sixty six thousand KB) 66 Megabytes?
Does the error happen when opening the file getting the file into the window ready to send - before sending. Or does it happen when you click the Send button? | |
By: Carlos Coderch | Posted on: Oct 25 2024 at 05:21:47 AM | Correcto sesenta y seis mil KB = a 66 MB
El error se produce al abrir el fichero y colocarlos en la ventana de preparación | |
By: Support | Posted on: Oct 25 2024 at 06:35:12 AM | The max allowed size of the text is 2048 MB
Have you done the Math? How fast are you sending the file. Sending 66MB at 9600bps will take all day. At least. Assuming there's no handshaking or other flow control.
Anyway.
I'm testing now with a file that is 121MB (One Hundred and Twenty One MegaBytes)
It took maybe 10 seconds for the whole file to be loaded into the EasyDnc/Remo Send window and it showed a spinner while it was loading the file.
When I clicked the Send button it locked up (not responding) for maybe 20 seconds or maybe a bit more while it figured out what to do then it started sending. Data scrolling up the screen as expected.
So handling very large files is not comfortable but, in my tests, it worked OK Your file is half the size of my test file so maybe your computer would handle the file better.
It's been sending now for around 15 minutes and the progress bar is still at 0%. File is so big that sending will likely take all day. I haven't done the math. 121MB at 9600bps? (960 chars per second)
I clicked the stop button and the program locked up again, window went blank for around 10 seconds and then display came back showing how far it had got.
My test computer is Windows 10 64bit and EasyDNC/RemoDNC will work in true 64 mode on a 64 bit computer but it shouldn't be a problem with a 32bit machine because the textbox size is a 32bit MaxInt
But if you do have a 64bit computer maybe you could try it just to see if you can load the file into the send window?
But another idea. Maybe the best option. Is to break the file into smaller sections making it easier to handle then you can run it at least once while you're watching You don't want to run it all night with nobody watching till you've tested it thoroughly. | |
By: Carlos Coderch | Posted on: Oct 29 2024 at 01:25:24 AM | Buenos dÃas; He probado con el PC de la oficina técnica y el RemoDNC carga perfectamente ( no puedo enviar porque no está conectado) Durante el dÃa de hoy probaré a enviar ficheros a la máquina con otro ordenador con windows 10 y 64 bits.
La opción de dividir los ficheros es la que he utilizado para continuar trabajando, estoy mecanizando unas resinas y el programa se ejecuta en modo continuo por lo que el tiempo que tarda en transmitir el archivo tiene una poca importancia, el CNC es bastante antiguo y no tiene capacidad para almacenar programas tan grandes.
En realizar la prueba con el otro PC té informaré del resultado, gracias por tu atención | |
By: Support | Posted on: Oct 29 2024 at 04:19:25 AM | g00gle translate
Good morning; I have tried with the PC of the technical office and the RemoDNC charges perfectly (I can't send because it's not connected) During today I will try to send files to the machine with another computer with Windows 10 and 64 bits.
The option to split the files is the one I have used to continue working, I am mechanising some resins and the program runs in continuous mode so the time it takes to transmit the file has little importance, the CNC is quite old and does not have the capacity to store such large programs.
In performing the test with the other PC I will inform you of the result, thank you for your attention
Thank you for your feedback. Keep us posted. | |
By: Carlos Coderch | Posted on: Nov 5 2024 at 09:08:26 AM | Hola Buenas tardes, al final el PC usado fue con Windows 11 y 16 DB de RAM. Se envió un fichero de 106.541 KB (106.5 MB) el fichero cargó en el RemoDNC en unos 10 segundos, cuando pulsé el botón SEND, la pantalla se puso en blanco , y después de unos 20 segundos empezó a transmitir. El programa ha estado en funcionamiento durante 46 horas.
Por mi parte tengo la solución al problema pasar a un sistema de 64 bits.
Gracias por vuestra ayuda, Saludos
Carlos Coderch | |
By: Translate | Posted on: Nov 7 2024 at 04:34:44 AM | Translation
Hello Good afternoon, in the end the PC used was with Windows 11 and 16 DB of RAM. A file of 106,541 KB (106.5 MB) was sent, the file loaded into the RemoDNC in about 10 seconds, when I pressed the SEND button, the screen went blank, and after about 20 seconds it began to transmit. The program has been running for 46 hours.
For my part, I have the solution to the problem of switching to a 64-bit system.
Thank you for your help, Greetings
Carlos Coderch | |
By: Support | Posted on: Nov 7 2024 at 04:35:56 AM | Thank you Carlos.
Happy to hear that your problem was solved by switching to a 64 bit computer, | |
