Topic: Every other line is Blank
By: Victor BiedryckiPosted on: Mar 3 2014 at 04:11:40 PM
I am sending programs to an Okuma lathe and every other line is blank. I had to install a new hard drive in the PC then re-install EasyDNC and thought I had the settings correct. Is there something I am missing. I am sure it is probably simple.
By: GuestPosted on: Mar 3 2014 at 09:01:45 PM
In easydnc setup look at the end of block. If it something like CRLFLF then change it to CRLF
If its already CRLF then change it to CR or LF on its own.
By: Victor Biedrycki Posted on: Mar 4 2014 at 04:44:11 PM
I set it to Ignore and that seemed to fix the problem... Thanks
