Topic: Fadal and Haas CNC Properties
By: recipsPosted on: Mar 28 2008 at 01:07:12 PM
Greetings, I am trying your software that I downloaded from the internet. My problem is that I can`t get the properties set up correctly. I have tried many variations with limited success, some but limited. I need to run the machine and trying different setups causes machine downtime and the boss doesn`t like that. Can you give me the setup info for the following machines? Fadal VMC20 1994, Fadal VMC4020 1996, Haas HL2 1996, Haas HL4 1998, and Haas SL30 2002. Thank you, Eric
By: GuestPosted on: Mar 28 2008 at 03:16:19 PM
We have found the problem. We had been using Fadal Assist since the machines were new. At the command screen we needed to insert a different command. Now on to setup the Haas. Thanks, Eric
By: SupportPosted on: Mar 28 2008 at 05:49:03 PM
Thanks for getting back to me. I deleted some of the posts from this thread because they`re were no longer relevant since you fixed the Fadal.
When esyDnc is in `Fadal` mode the small windows that appear are Fadal command windows allowing you to enter the fadal commands directly into easyDnc instead of going to the CNC console.
Let me know how you get on with the Haas.
