Topic: Fagor 800 control
By: TextoolPosted on: Nov 20 2007 at 05:41:16 PM
About 1 year ago we purchased your product and, with the help of the Clausing factory rep, sucessfully had it working on a dedicated pc directly connected to a Clausing lathe with a Fagor 800T control.
About 2 months ago, the PC was stolen and you helped up replace the software. We reloaded the softwared, ran the "set-up" routine and were able to send programs from the machine to the pc but was not able to send programs from the pc to the machine. Our time ran out at the supplier so we recommended that he contact the factory rep again for help. To date the factory has not been helpful. It`s been a long time but it seems that the factory rep added information into the "asci" fields on the software so that the machine would receive from the pc but I can`t remember.
Do you have any suggestions?
By: SupportPosted on: Nov 21 2007 at 04:26:35 PM
I assume you`re using a version of easyDnc where there`s a button in setup labelled `Advanced` and when you click that a window appears where you can enter Ascii start and end codes.
Try the Esc (27) option in the End code. (select it from the drop down or simply enter 27 into the box)
Look at the program text you`re trying to send. Does it contain a % symbol at the start ? If it does then you don`t need to add any more ascii codes to easyDnc setup.
If there is no % symbol at the start of your programs then enter 37 as the Ascii Start code into easyDnc setup.
By: Prof. Wilmer SalazarPosted on: Oct 2 2009 at 06:10:22 PM
En Panama compramos 9 tornos pinacho s94 c 200 con controlador fagor 800 t, el de mi escuela, traia la tarjeta del flyback con partes reconstruidas, se quemo y el monitor y mas nunca sirvio , a pesar de que costo sumamente caro para el pais, el colmo es que no solo fue este el que se compro, sino 8 mas para otras 8 escuelas,a TODOS SE LES DAÑO EL MONITOR, CON LOS MISMOS SINTOMAS, no es la coneccion electrica puesto que estan distantes en el pais uno de otro asi q no pudo haber tal coincidencia para el mismo daño; solicito a la Fagor, que trate de remediarnos la situacion, QUE PODEMOS HACER. Midireccion es west21naza@yahoo.com; Panama, telefono: (507)-6672-8783
By: Support Posted on: Oct 3 2009 at 11:31:57 AM
Siento mucho.
Nosotros sólo podemos ayudar acerca de software de easyDnc
