Having trouble communicating with this control. Have tested using a known good cable and serial port that can communicate with another fanuc control. Cable is pinned out per reccomendations on this site under cable 2 diagram. As soon as we hit the input button we get a quick LSK flash and then a "086 P/S ALARM" alarm. Any thoughts? Double checked params and didn't see anything obvious. Also tried setting EasyDNC to port scan and get the same almost immediate "086" alrm when we hit output.
By: Support,
Posted on: Mar 2 2011 at 10:46:51 PM
Fanuc alarm 86 happens when the cable is not correct.
At the CNC end of the cable you should make a shorting link between pins 6-8-20
Please check that cable again. It may have the link to pin 8 missing or loose solder which may still work with some machines but not others.
support at easydnc.com
By: Sunil
Posted on: May 31 2017 at 03:06:48 AM
Ps alarm
By: León de la metro
Posted on: Dec 17 2022 at 03:09:18 PM
No puedo recibir nada
