Home
Prices
Topic: Fanuc 0T
By: Dan Lewis
Posted on: Aug 14 2013 at 03:27:19 PM
If the "Runner" program must use parenthesis to enclose the requested file,
Fanuc 0t does not have this character on the keypad.
What now?
Posted on: Aug 14 2013 at 07:39:11 PM
Remo version 3 used to work without parenthesis like this
O9999
P1234
M30
In remo setup set O9999 as the request tag.
The P tells remo that 1234 is being requested.
The M30 is not necessary. Just there out of habit.
That was how v3 worked. If im not mistaken v4 can also use the v3 syntax. Give it a try.
Topic: Fanuc 0T
