using dncxp several minutes into drip feed
getting erro initializing port exteneded code
ext err
can someone help
thank you
By: Support,
Posted on: Oct 27 2010 at 12:07:52 AM
What kind of com port is it ? USB ?
support at dncxp.com
By: Guest,
Posted on: Oct 28 2010 at 02:50:13 AM
rs232 9 pin
i have a takisawa macv2e with a 10 m fanuc
using a emachine t3304 windows xp
paramenters on dncsetup work with the exception
of the input and output devices when i change from o to 1
i get a start reject
if left at 0 it will dripp feed for a few minutes
then i get sr 834 buffer overflow (2) alarm
have tried changing all setup settings with no luck
By: Guest,
Posted on: Oct 28 2010 at 02:57:33 AM
also using full handshake (cable 2)
By: Guest,
Posted on: Oct 28 2010 at 05:18:24 AM
also using easydncxp
and have fifo disabled
By: Guest,
Posted on: Oct 28 2010 at 05:24:43 AM
v2.1
By: Other Guest,
Posted on: Oct 28 2010 at 02:59:17 PM
Check in the machine parameters - are their options to use DC1 and DC3 (not DC2 and DC4)
Some machine also allow you to change the values of DC codes. Should be DC1=17 DC3=19
