| By: Guest | Posted on: Dec 16 2013 at 09:08:12 PM | Sometimes file transfer will not run, even if all the settings are correct.
The following procedure may correct the problem, especially if you're running the machine via DNC:
Check to make sure your FIFO buffers disabled on the PC.
You access the settings in Control Panel -> System -> Hardware tab -> Device Manager.
Find your COM ports and double click the one you are communicating with.
Click the tab for Port Settings then Advanced. Uncheck the FIFO buffers.
Having this turned on can cause problems with RS232 transfer, especially DNC. | |
