Topic: FANUC 15Ma & 15Mb
By: GCPosted on: Dec 21 2007 at 01:21:25 PM
We are having issues trying to drip feed files to the controllers. No matter what settings we use both controllers give the error "Buffer Overflow" while drip feeding.
The PC`s are running Win-Vista (home).
We`ve turned off FIFO. Slowed the baud rate from 19200 to 9600. We`ve also tried Xon/Xoff (std) and Xon/Xoff (wait). Confirmed controller communication settings (data bits, parity, stop bits & flow control). All these changes at some point gave the same result.
The buffer overflow occurs at different locations. When the overflow occurs the EasyDNC is still waiting on a comunication from the controller to send more data.
By: SupportPosted on: Dec 21 2007 at 05:10:20 PM
In easyDnc`s setup is a parameter labelled "Block Delay" Try increasing that to the max.
By: GuestPosted on: Dec 21 2007 at 05:30:08 PM
Been there done that, maxed it out and still had the same problem.
By: SupportPosted on: Dec 21 2007 at 06:34:47 PM
What happens if you take the baud rate down another step - maybe 4800 or even 2400. At those speeds you probably won`t need such a large BlockDelay.
I`m not saying you should run at such a slow speed permanently but just try it to see what happens.
It really depends on the speed of your machining process - if you machine quickly at a low baud rate then the cnc`s buffer will run out of data and the process jerks and stutters which isn`t good. But often the machining process is quite slow so high baud rates aren`t always required.
Send me an email.
support3 at easydnc dot com
By: GuestPosted on: Dec 21 2007 at 07:54:13 PM
That is on my list of things to try. At the moment both machines and PC`s are tied up with work. I`ll have an answer for by the end of next week.
By: GuestPosted on: Dec 26 2007 at 03:57:56 PM
I finaly got to test the 4800 setting on the controller and got the same result. Anything else we can try?
By: nzrainPosted on: Dec 28 2007 at 02:49:25 AM
[quote:0450dc8a00="Anonymous"]I finaly got to test the 4800 setting on the controller and got the same result. Anything else we can try?[/quote:0450dc8a00]
Hello.
I have a 15M controller and I had the same problem, but I changed one of the settings from at 3 to a 4 in the controller and it fixed the problem.
Cheers.
By: ISPosted on: Dec 28 2007 at 07:44:57 PM
GC - email support at
By: ISPosted on: Dec 28 2007 at 07:46:04 PM
NZRAIN - any information on `which` setting you changed would be interesting.
