Topic: fanuc error SR 824 buffer overfollow
By: GuestPosted on: Jan 6 2016 at 04:19:08 PM
I just installed a new version of 5.0 and now I have this error SR 824 buffer overflow. "THE NC RECEIVED MORE THAN TEN CHARACTERS OF DATA FROM READER INTERFACE 1 EVEN THOUGH THE NC SENT A STOP CODE DURING DATA RECEPTION."
I didn't have this problem before. Any ideas?
Paul
By: SupportPosted on: Jan 6 2016 at 11:04:41 PM
Hello Paul,
In your email today i got the impression that you were saying that the dnc did work correctly but then you'd got a new computer.
Make sure you have flow control (xon/xoff) enabled in the dnc setup.
Disable windows FIFO. in your email you said you'd adjusted it. But it needs to be disabled completely.
In the dnc setup you see a setting for Block Delay. Increase that to a higher number. (longer delay).
If your baud rate is high then consider lowering it.
By: SupportPosted on: Jan 9 2016 at 08:21:19 PM
Hello Paul. Thanks for coming back to us (by email) saying that The fault appears to be with the PCI card and that using a USB/Rs232 adapter instead of PCI has fixed the overflow problem.
That other minor thing you mentioned - having to press the cycle start button on the CNC twice when repeating the same program - we'll order a usb adapters identical to yours and run some tests and hopefully get a solution for you.
