I have everything working properly except for when I transmit data to the Anilam controller. The program is uploaded cleanly except at the end of the transmission of the program there will be garbage text, mostly consisting of the letter "B", maybe 30-50 of them. It does not matter the size of the program (large or small) or the baud rate (1200 versus 9600). I can separate the garbage text from the program being uploaded by adding in a couple of Carriage Returns to the end of the program prior to uploading. It sounds like a software problem????????
Posted on: Mar 30 2012 at 09:16:30 PM
Sounds like tape leader/trailer being sent or interpreted incorrectly.
I never heard of this with the Windows version. Maybe a fault in the non-windows versions although it's never been reported before.
I have continued to try other ways to correct the problem without success. I continue to have the same problem. Can I send information to someone to help diagnose the problem??
Posted on: Apr 9 2012 at 09:22:51 PM
Email address is
support at easydnc.com
I assume you"re using windows (ie not Linux or apple/MacOSX)
What version of the software is it ? Near the top of the program window is a yellow (?) question mark button. Click that to see the version number.
In easyDnc setup There is a "Mode" option. What is that set to? Try setting that to "None".
