Topic: GE Mark Century 2000 control
| By: duaneq | Posted on: May 30 2007 at 09:01:49 PM | | We downloaded the trial version of EasyDNCxp and we got the cnc control to send programs out but we get a read/write error and I/O error when we try to send programs back into the control. We are going through rs232 cable into a usb converter into a laptop. The settings are 4800,7,1,none, xon xoff. | |
| By: Support | Posted on: May 31 2007 at 04:14:37 PM | In easyDnc`s setup is a setting for block delay. Try increasing that to the maximum value.
When you send the file does the error happen instantly or does it look as though the control is taking the data for a while before the error happens. If the change to the block delay made any difference does it make the control error happen later or does it happen as soon as you click send on the computer ? | |
| By: duaneq | Posted on: Jun 1 2007 at 12:34:09 PM | | The error is instantly. We are thinking it might be the pin out isnt correct. We are going from 25 to 9 pin and with an rs232 tester not all the lights are green. we made a new cable to make sure, off of the standard rs232 pin out you have in your online manual and still can`t get programs into the control. | |
| By: Support | Posted on: Jun 1 2007 at 05:57:00 PM | If the error happens instantly then I`d say that the cable is correct because data is getting through to the machine. But the machine doesn`t like what it`s getting.
Could indicate an error in the data format.
The program you`re trying to send IN to the machine. Does it look the same as data that comes OUT of the machine ? For example, when data comes out of the machine, the start of the program might have a % symbol followed by the program name/number. The data you`re sending in to the machine would usually need to follow the same layout.
In easyDnc`s setup is a parameter for `End of Block (or Block End) This has options such as CRLF or FAST (or NONE) try changing that. If it`s set to CRLF then change it to Fast (or NONE) or one of the other settings. | |
| By: duaneq | Posted on: Jun 4 2007 at 12:29:21 PM | | The data coming out is the same as our old programs that we are trying to put back in. I tried changing the stop bit and it still has the read/write error. | |
| By: Support | Posted on: Jun 4 2007 at 07:08:09 PM | Did you try the different Block End settings ?
Also try changing the Mode in easyDnc setup. Default, I believe, is `Standard`. try changing it to `None`.
Have you ever (successfully) used any other software with this machine, maybe an old Dos program ? If you have, would you email me at:- support2@easydnc.com | |
| By: Billy Patton | Posted on: Sep 22 2009 at 01:23:55 PM | | This 2000 is used on a wotan mill, on the position page, on the far right, at the grid % all the number are 85 or above, how do I reset this back to zero? | |
| By: IVAN JOSUE SANTOS, | Posted on: Mar 3 2010 at 11:13:36 PM | | GEK-25387 MANUAL | |
| By: Guest, | Posted on: Mar 10 2010 at 12:11:36 PM | One thing I notice about the very first post in this page is that duaneq used 7bits with NONE parity. That is very strange. I would suggest that he should try EVEN parity.
If that doesn't fix the problem then it is either an error in the program format - Maybe some special start or end character that you need to add to the start/end of the file.
Or it may be a buffer overrun - search the forum for FIFO | |
| By: bob, | Posted on: Mar 10 2010 at 07:43:13 PM | | hello my problem is the control letters are tyo small to read. I`m hoping someone knows how to adjusts to regular size | |
| By: Carles Vila, | Posted on: Mar 23 2010 at 12:03:21 PM | Hi.
I have a Little problem. In the CNC I can’t delete two programs . The message of the machine is “DELETE PROTECTED”. Thanks again.
Best Regards.
| By: Guest, | Posted on: Mar 23 2010 at 07:57:31 PM | | Some machines have a number of programs or sub programs which can not be deleted. They're part of the machine operating system, maybe a common tool change or some other function. | |
| By: Mick354, | Posted on: Oct 4 2010 at 10:37:21 PM | Hi
to send a file back to the cnc you must edit the prog, input a $ at the very start of the File and also input a % At the end of the file.The file will load to The cnc index with no probs.
REGARDS
| By: Brett | Posted on: Jan 31 2012 at 03:41:06 PM | | We are getting 6452 error code on our Leblond baron 25 lathe, when we hit the emergency E-Stop button as it says it cyles through the error messages, but never clears them out. Any idea as to what needs to be done to get the machine up and running? | |
| By: Guest P LUSTY | Posted on: May 1 2013 at 08:26:31 AM | | DOES ANY ONE KNOW THE M CODES NEEDE TO GET THE LIVE TOOLING GOING ON THIS CONTROL. | |
| By: IMZOURH | Posted on: May 11 2025 at 09:47:35 PM | | CODE De programmation sur tour cnc GE Mark century 2000 | |
