Has anyone attempted to get this software to work with a TNC151 Controler on a Bridgeport Interact 412? :?:
By: Other
Posted on: Jan 20 2006 at 07:26:09 AM
i had no problem using easy dnc on a 155 control ,just set the protocol method to ME, yo can try the other ones (EXE ,FE) they are found when you press the mod key when in edit mode
By: Bob
Posted on: Jan 24 2007 at 07:47:14 PM
Yes I have used it on a 151 control.
You need to read in program selected & type in the prg #.
If that doesn`t work you have to make sure the first line of
information in the program is indented one space. I do not know
why that is but, I have 3 151 controls & they all need that. I edit the file
in notepad.
Hope this helps?
Bob
Posted on: Nov 13 2013 at 01:12:03 AM
hi bob .
can you tell me how can I send a g code to tnc151a bigger then 3200 line? is there a way to send g code continously while working to be able to run a 20000line g code?
thanks in advance
regards
pierre
Posted on: Nov 13 2013 at 09:03:44 AM
Send coninuously while working (drip feeding) is not possible on all heidenhain controls.
