Topic: Heidenhain TNC_151
By: BeePPosted on: Apr 11 2008 at 01:30:36 PM
Hi,
Just downloaded the trial version but I can`t get it to send anything to our old tnc_151.
Can anyone help with the settings or perhaps it is under the advanced tab.
Also our yang is receiving but I would like to start it from a set point in the prog, we generate our codes using edgecam & it prints a header with cutter info etc at the top, I would like to be able to miss this out & only send from the colon (:) onwards.
By: GuestPosted on: Apr 15 2008 at 11:48:15 AM
I`m not aware of any specific problems with 151 controls.
Here`s a link to somebody asking the same question elsewhere on the forum.
http://www.dncxp.com/forum5/viewtopic.php?t=145
I have a 150 and a 155 and all I do is get into parameters with the 95148 code and set the interface type and data format on the control like this
Interface type = EXT
MP222 = 104
MP92 = 1
By: FredPosted on: Apr 15 2008 at 05:28:56 PM
When the program is loaded ready to send you can simply delete the unwanted text from the top if the transmit window.
