program transfer condition program incomplete alarm occurs
Posted on: Feb 17 2020 at 05:06:10 AM
On any machine this would usually indocate that somethng is missing at the end of the file. Maybe % symbol?
By: Matt
Posted on: Feb 17 2020 at 05:21:01 AM
Program Incomplete error
Would usually occur if the CNC was configured to use the blockwise protocol (FE Mode) and you tried to send the program from the computer in another mode such as ME (Tape Mode) The might be thrown when the CNC does not see the correct blockwise protocol.
Or if you have easydnc setup to Heidenhain Blockwise then maybe it's because your rogram is indeed not complete - something missing?
Is easydnc set to Heidenhain Blockwise?
Posted on: Nov 4 2026 at 08:51:16 AM
'When' does the alarm occur. If it occurs at the version start of the transmission then the settings are wrong. If it occurs part way through - ie some data is transferred before the alarm occurs - then there is an error in the data or data was lost
