If so, How would I find out how to make an interface cable for this
As of right now I have a DB9 to DB9 straight pin, maybe I need to way pins 2 and 3?
I don't see any selection for Hurco on other machines.
Posted on: Sep 7 2011 at 09:26:30 PM
Assuming your CNC has the standard hurco 9 pin port your cable would be a crossover like this.
2 - 3
3 - 2
5 - 5
7- 8
8- 7
Pins 7 and 8 are for RTS/CTS flow control. If you're not using that then you could ignore them and just make a short link between pins 7-8 at each end of the cable.
