Topic: I've got 2 x 8port USB boxes. Will this work
By: Guest James
Posted on: Jan 15 2020 at 07:00:11 AM
I've got 16 Com Ports. Will this software support that many?
By: James
Posted on: Jan 15 2020 at 07:03:40 AM
Sorry. Ignore my question. While I was posting the question my cnc guy had downloaded the trial and was testing it already - works great. Happy :)
By: James
Posted on: Apr 24 2020 at 04:33:02 AM
Just wanted to come back and say we've upped this now to 24 com ports and all working fine.
Had a few head scratching minutes when the usb cables on the original boxes were unplugged and possible reconnected in different usb sockets or different order and windows gave them all different com port number.
Even if you just have one USB cable I'd say dab little color paint spots on the connector and computer just above the port so if anything is disconnected you can be sure to connect it all back up right.
By: Dave
Posted on: Jun 8 2020 at 03:32:06 PM
James - are you using a usb to serial box? or 3 x 8 port (RS232) connected to your pc via single USB?
Dave
By: James
Posted on: Jun 9 2020 at 07:07:28 AM
Dave. it's a box with 8 rs232 ports on one side and one usb port connected to the computer. 3 of those so using 3 usb ports.
24 RS232 cables stretched over the shop from PC to individual CNCs isn't ideal though. If you're just setting out and you need quite a few CNCs connected over distance then I'd suggest looking at WIFI-to-RS232 boxes. That way you can place the boxes nearer the cnc machines and reduce cables.
By: Michael at RCB
Posted on: Sep 24 2026 at 08:28:33 AM
I know this is an old post but just wanted to say that that Ethernet/wifi option really is excellent. We have machines way beyond the usual RS232 range and setting up a wifi ap at that end of the shop connects all my machines.
