Topic: Ignoring Spaces when transfering from DNC
By: GuestPosted on: Apr 13 2011 at 03:33:18 PM
When I transfer from the DNC to CNC on a Fanuc 15 HG630, the program is loaded but all the End Of Blocks (;) which separate each program part are gone.
When i program i like to seperate each tool with a few EOB's (;) and the end so it makes for easy reading on the screen.
Is there anything i can change in the setting to help me do this?
By: SupportPosted on: Apr 13 2011 at 09:29:52 PM
In easyDnc setup there is an option for end of block. It's probably set to CRLF. Set that to NONE or IGNORE
That makes easyDnc send the data exactly as you wrote it.
