Topic: LODIND PROGRAM TO THE MACHINE
By: GuestPosted on: May 11 2016 at 03:21:50 PM
NO ALARM MACHINE IS WATING, REMO IS SENDING BUT PROGRAM IS NOT GETING TO THE MACHINE
By: SupportPosted on: May 11 2016 at 07:39:58 PM
What machine is it?
By: SupportPosted on: May 11 2016 at 07:42:02 PM
What happens If you send a file from the CNC to the computer? That might not be the direction you want to go but it's usually easier to diagnose problems so please try that and let us know.
By: GuestPosted on: May 11 2016 at 08:49:00 PM
From the machine to computer works fine only from computer to machine nothing is happening.
Machine tipe is Miyano with fanuck OM control
By: GuestPosted on: May 11 2016 at 09:55:26 PM
I faund the problem. setings on port were diferent than on remo
By: SupportPosted on: May 12 2016 at 03:57:12 AM
Thank you for coming back to let us know you found the problem.
Usually if there's a setting causing a problem then a Fanuc OM would throw an alarm. But in your first post you said there's no alarm. It would be interesting to know which setting caused the problem. Thanks.
By: GuestPosted on: Jul 6 2016 at 05:58:47 PM
when I was using on trail version worked fine both ways. Now with the new license I can send to the machine but from the machine is not receiving. Help
By: GuestPosted on: Jul 8 2016 at 09:12:28 PM
There's no difference between versions. Its exactly the same program. The activation code simply cancels the trial expiry. No changes are made to the software or to the cnc settings.
Please have a good think about what else might have changed. For example did you run the trial on a different computer?
