Topic: Long File Names
By: RickPosted on: Jul 28 2006 at 09:29:13 PM
Does easyDNCXP support long file names. Would a Fanuc control care what the file name format is as long as the program it receives is formatted correctly?
Rick
By: SupportPosted on: Jul 31 2006 at 01:14:37 PM
Yes, easyDnc support long file names.
And, as you say, a fanuc doesn`t care what the `Windows` file name is. For example, you might have a file such as:-
O1234
M30
And if you save the file in Windows with a long name such as:
"This is a very long filename.txt"
Then that filename is only seen by windows (and easyDnc) The fanuc on the other hand just sees the "1234".
