i would like to know if your software is compatible with the MAZAK MTV-515/40N
thanks a lot for you help
with my best regards
Posted on: Dec 1 2009 at 10:56:28 AM
Download the free trial. That runs a couple of months giving you plenty of time to try.
Start the software - Double Click the "Add Machine" Icon to add a new machine icon.
Right-Click the new machine icon and select "Port Scan"
Then go to the Mazak and Send/punch out a program. easyDnc will try to detect all the settings for you.
Before you start - most older Mazak controls communicate using a special mazak protocol but they can also be switched to use standard ISO/Ascii - check your documentation to see if your control is set to use the mazak protocol or ISO - it's more compatible with DNC software of you use ISO
By: romss
Posted on: Dec 3 2009 at 07:35:59 AM
Know you if it is possible to work directly in bandwidth because our machine has not enough memory(report) to store our program
Posted on: Dec 3 2009 at 07:50:41 PM
I don't know if your particular machine is capable of "Drip Feed".
Machines that can run with drip feed usually have options such as "Tape" mode or DNC mode. In this case you'd prepare the program on easyDnc's output window ready to send and you'd set the CNC in Tape/DNC mode and hit Cycle Start. At this point the CNC doesn't do anything. Go to easyDnc and hit the "Send" button - as data starts to flow the CNC starts machining.
But, as I said, I don't know your machine so don't know whether your machine is capable of operating like that - check your machine's documentation.
