I HAVE LOST THE COMMUNICATION FROM MY DESKTOP TO MY MAZAK.
I CAN SEND CODE FROM MAZAK TO DESKTOP, BUT CANNOT SEND TO MAZAK
Posted on: Jul 30 2012 at 07:54:41 PM
If it 'was' working and suddenly it's not working and you're sure that you've made no changes to the settings then take a close look at your cable connections. Solder joints etc.
Posted on: Aug 20 2012 at 05:36:52 PM
I HAVE BEEN TOOO INVOLVED CREATING PROGRAMS TO GET BACK TO THIS.
THE ONLY THING WE REMEMBER DOING WAS CHANGING THE STORAGE BATTERIES
IN THE MAZAK. THIS IS DONE WITH THE MACHINE "ON". CAN'T REMEMBER IF WE
SENT A CODE TO THE MACHINE AFTER THAT OR NOT. I AM USING A FLOPPY TO TRANSFER THE CODE TO THE MACHINE ... IT IS A HASSLE.
Posted on: Aug 21 2012 at 10:05:33 AM
If it was working before changing the battery then some of the setting must have changed.
Take a look at the communications settings in the CNC. Baud rate etc. When you try to send to the CNC what happens? Are you able to send from the CNC to the computer? That direction may not be what you want but CNC to PC is often easier to diagnose.
Posted on: Aug 25 2012 at 12:50:07 AM
I CAN SEND FROM THE CNC TO THE DESKTOP COMPUTER.
WHEN I SEND TO THE CNC FROM THE DESKTOP, IT DOES NOT SEND
ANY DATA TO THE CNC.
I HAVE A "PRINT SCREEN" OF MY SETTINGS WHEN IT WAS WORKING AND ALL THE SETTINGS ARE THE SAME AT THE MAZAK & IN THE EASY DNC. THIS IS WHY I AM CONFUSED. I AM "DEAD IN THE WATER" AND NEED A CONTACT OF SOME KIND!
Posted on: Aug 25 2012 at 02:33:18 PM
Email
support at easydnc.com
But I'm guessing all they can do is tell you what settings to use. You already know what settings to use because you already used them successfully and if the software hasn't changed it seems obvious that something with your hardware HAS changed.
