Topic: Mazatrol M plus
| By: RIMONI | Posted on: Jan 19 2017 at 02:19:18 PM | Hi, i'm having problem in tape mode,
when I send a program to the memory there is no problem,
when I try to work in drip feed mode, the program work till the firs stop
and then an tape IO error, and the machine stop.
I try to slow baud rate to 2400 and block delay to the maximum but no change.
| By: RIMONI | Posted on: Jan 19 2017 at 03:05:35 PM | Found a solution, change wait for machine to repeat.
