Topic: Mazatrol T32
By: GuestPosted on: Apr 16 2007 at 08:40:29 PM
Will this work with a Mazatrol control?
By: BonGPosted on: Apr 17 2007 at 11:16:27 AM
Many `Mazak` controls use a special mazak communications protocol which most DNC software does not support. Obviously mazak want you to buy their own programming devices. There is a company called `Griffo Bros` where you can get special mazak program software, communications, offline programming etc. I don`t know their website address but if you google for "griffo bros mazak" you`re certain to find them but, be warned, it can get very expensive.
If all you want is simple file transfer then you can change a setting in your mazak which makes it communicate using industry standard `ISO` which easyDnc will work with so you should be able to use easyDnc to transfer files to/from your mazak control.
