Topic: Moxa wifi Port Server
By: GuestPosted on: May 19 2026 at 12:59:24 PM
Can easydnc connect to the moxa port server over wifi to the moxa's IP address?
By: JasonPosted on: May 20 2026 at 05:38:41 AM
Yes. In easydnc setup there's the Com Port setup. This lists available Com Ports but at the top there's the "IP Address" option. Select that and a box appears where you key in the IP address of the moxa box.
There's a pdf somewhere explaining it. maybe support will post up the link
By: GuestPosted on: May 20 2026 at 06:30:00 AM
This link should get you the PDF
Moxa Setup
