| By: Support, | Posted on: Mar 19 2010 at 12:46:05 PM | If the program gcode is lots of lines for each small movement then the data has to be fed through very quickly although 4800 would often be fast enough. If you have the block delay/block end set to fast and it's still not fast enough then you will need to run at 9600.
But, as you said, 9600 causes the overrun alarm - we can work on that. First thing to do is switch off the Windows FIFO.
Control Panel > System > Hardware > Device manager > Comports
Select the com port > Port Settings > Advanced.
This bring up a window with options for the Com Port FIFO. You don`t need to adjust any other com port settings via this tool, just make sure the FIFO is disabled. (Slide the sliders down to zero and uncheck the checkbox)
Try disabling the FIFO first - and if you still get occasional overruns try increasing the block delay. | |
