when we try to load from pc to osp it gives me 2132 time out error code. Have tried rewiring the cable to different set ups and always the same. This is on a mvc-4va.Punching from machine to pc works ok. Any help appreciated.
Posted on: Nov 27 2011 at 11:40:40 PM
Some okuma expect the file to begin with a $ dollar symbol.
Before sending the file try editing it so that it starts like this. The file that is punched out of the okuma might not look like that. There will often be a lot of spaces between the $ and the % symbols as well as the FILENAME but you can edit it so that it looks like this before sending into the okuma.
$FILENAME.MIN%
(And ends with a % symbol)
The okuma might not output those symbols but the file often won't go back in unless they're there. That % at the end is often missing and will cause the time out if missing.
