Topic: okuma LB25
By: ArgoMCHPosted on: Sep 13 2004 at 01:34:07 PM
Am having no luck communicating with our LB25 and was wondering if there are any machine parameters that need set before this can work. the control is an OSP5020L.
By: adminPosted on: Sep 13 2004 at 07:47:34 PM
Hello Argo,
No, there`s no settings for easyDnc, it`s supposed to be automatic. At the Okuma you need to set up a couple of things
There`s an optional Parameter bit settings #1 00001011 ISO code
and #2 10100010 sets up the stop bits, parity etc.
Paremeters 44,45,and 46 all zero and 54=1. Sets up the read/write punch devices etc.
To send/receive data F3 PIP Then F1 or F2
There`s also a parameter fro the tape leader. Some recommend setting it to zero but shouldn`t be a problem as long as it`s not huge (otherwise it takes ages to send lots of nothings)
But, after all that there might be something in easyDnc that`s stopping it working. been a while since I tested it on an okuma. I`ll take a look and let you know.
maybe send me an email so we can exchange info by mail and I can send an update straight to you if anything gets updated
By: Guest Richard Bauer,Posted on: Nov 27 2010 at 07:22:51 PM
I have a okuma lb25 with a 5020 controler I need to change the chuck to gripping inward instead of outward, I understand this is done in the parameter, but which one? also I need to turn on and off the tailstock in the parameter which one does that? I have the books but it doesn't tell me. thanks if you can answer RB
